Re: Alternator shot??
I thought that was it since one of you guys said it was a triangular flange with a single wire going to it. But anyway, the single wire doesn't look corroded or cut or anything so I guess that's not the reason for the P1259 code??
Above the triangle flange is the VTEC solenoid. The whole thing is called the spool valve assembly. Now that you've found the spool valve assembly, go back to the picture I put in post#5...
The VTEC oil-pressure switch is #14 sticking out to the side, down lower on the spool valve. Down off the lower-left of your first picture. THAT's the plug (2-wires) for you to check.
#17
Alright I looked at your earlier picture. So I guess the screen would be inside the spool valve assembly right?? This shouldn't be too complicated for me to hopefully?? I'll give it a shot one of these. If I break my car then I declare myself awful at life. lol..
#18
The screen is sorta part of the gasket (#13) where it bolts against the head. Picture shows it like a separate part, but I've seen it molded into the gasket. On second thought, I'd buy a new gasket.
But if there's sludge, I'd clean out the entire spool valve assembly.
reinventingaxlrose
01-25-2008 01:29 PM
