Reading SRS code
Old 12-28-2021 | 01:23 PM
The OBD1.5/2 standard connector has 16 pins. The issue with numbering is that honda numbered them differently in the shop manual vs the OBD2 standard. This can get confusing. I'll make a writeup at some point to help ensure folks don't short the wrong pins.i
Shorting the wrong pins on the obd2 connector can send 12V directly to the PCM and fry a circuit, so triple-checking your car's obd2 pins and seeking advise on here before attempting is a good idea. Also, the shop manual for your car is essential for this kind of work.
Old 12-28-2021 | 03:31 PM
While it is true that the SAE numbering is different than Honda's numbering in the service manual, the white/grn wire protected by the ACGS fuse (under-hood fuse no. 46) is not at SAE numbered terminal no. 5 or Honda service manual terminal no. 5.
The following is from Honda's ETM, which is updated compared to the Honda service manual.
dogmarcopolo
03-22-2013 09:29 AM
byrdi
01-22-2010 06:55 AM
Antarctica
07-07-2008 02:49 AM
caverspencer
11-12-2007 09:10 PM
Becker
10-16-2007 05:14 PM
Quick Reply: Reading SRS code
