Rear crankshaft seal engine leak
My daughter's 1998 Accord has 250,000 miles. She has had it for 8 years and 100,000 miles.
I have done a lot of work keeping it running and now it has a leak at the crankshaft seal (the side that goes into the transmission). I am having to add 1/2 quart to 3/4 quart every 2 weeks.
I am borderline on giving up and saying it has been a good run. I read the Haynes and Chilton manuals and both say to "drop the engine".
When I look at the engine, I would think I can separate the engine from the transmission and raise it up enough to remove the flywheel, then change the crankshaft seal, then drop the engine back in place.
Is there any easy way ( or shortcuts) to replace this seal?
I have been checking Honda CR-V's as a back up plan in case I really give up. Anyone have any opinions about CR-V's?
PS, I am not sorry I got this car. It was fairly easy to work on and repair. Just sad that this may be the end of the road over a $20 part.
It's not like it owes you anything, and it must still be a reliable car, if you're thinking about replacing the seal.
Yea, that's the thing, I can do brakes, alts, replaced the gear position sensor last year, etc...
But the idea of taking 2 days for a 22 year old car and the car is barely worth $1000- makes be think it's time to move on.
Or maybe just go ahead and put it out of it's misery
If you have the proper tools I say it's worth spending the weekend to get some extra months out of it. Depending on how long you are wanting to keep it you're only spending $20 and time. But you know best what you're time means. You'll have to do maintenance on the CR-V if you purchase one used. They are solid.
Is her car a manual or an automatic? If a manual, it might be getting time for a clutch, so killing two birds with one stone might make sense. When it was clutch time on my TL I ended up dropping the transmission and then did the rear main seal while the tranny was out.
It's an automatic. With whats going on ( virus, etc...).. I think I'll just check the oil every other week and see how it goes.
At least, there is no pressure to make a decision in a hurry.
Thanks everyone for their inputs!
landlover
05-15-2009 07:22 AM
