Rear disc brake swap 94 accord
Old 09-22-2009 | 10:28 PM
jesselap's Avatar
Default Rear disc brake swap 94 accord
Hi,
Just curious on how involved it would be to convert my rear drum brakes to disc brakes on my 1994 honda accord coupe. If anyone has any idea's, or comments on if this is even worth it, please let me know
Old 09-22-2009 | 10:48 PM
Its probably not worth it.
You would definitely need a caliper, brake pads, rotor. The knuckle/hub from an EX from a junkyard, I think.
I'm not sure if the e-brake or the hydraulic lines are the same between the EX vs the LX/DX. You would have to go to a parts web site and see what part numbers are the identical between your accord and the EX accord to eliminate the parts you would need to buy.
Old 09-23-2009 | 08:17 AM
I think the wheelbearing/hub is the same, but the knuckle is different. Probably the spindle is different.
I'm pretty sure the handbrake cables and the hydraulic tubes are different.
If you're lucky the suspension control arms are the same??
If you have ABS, the wheel-sensors might be different?
Old 09-23-2009 | 08:56 PM
jesselap's Avatar
Thanks,
All I needed to know. I don't think it would be worth my time
jrzwalker86
12-05-2011 07:49 PM
sean
07-19-2011 01:31 PM
Andy2k9
05-15-2010 06:31 PM
sirgilligan
12-22-2008 11:47 PM
KevinAccord
05-21-2007 02:59 PM
