rear motor mount
Old 08-03-2008 | 02:43 PM
shaun8484's Avatar
Default rear motor mount
Hi my name is shaun and i am new to the forum. I have a 95 ex and was wondering if anyone could tell me if the rear mount has a solenoid or not.
Old 08-04-2008 | 09:19 AM
Default RE: rear motor mount
Not until you finish telling us what kind of car...
Manual tranny = normal rubber mount.
Automatic tranny = vacuum-operated mount with a solenoid valve on the vacuum line.
BTW, Welcome! Lots of expertise around here, if we know what you have, and if we can post.
https://www.hondaaccordforum.com/Sti..._128656/tm.htm
Old 08-05-2008 | 10:16 PM
shaun8484's Avatar
thanks oh its an automatic 95 accord. after i read your reply i went to check it out and i did not see a vac line anywhere
Old 08-05-2008 | 11:29 PM
Post #6 in here is pretty much the same.
https://www.hondaaccordforum.com/m_1.../tm.htm#133464
Old 08-05-2008 | 11:40 PM
shaun8484's Avatar
thanks much i was not able to see it from the drive side.
Old 08-05-2008 | 11:47 PM
Welcome to the forums...
Old 08-05-2008 | 11:49 PM
shaun8484's Avatar
thanks wheel.
Old 08-06-2008 | 08:21 AM
The parts drawing I posted in that other thread is kinda pathetic for the actual location & routing of that vacuum hose. Unfortunately I dont have any better...
Maybe from underneath you can follow the hose from the mount itself?
Old 08-07-2008 | 01:36 PM
shaun8484's Avatar
is there anyway to run the mount with out the solenoid
Old 08-07-2008 | 03:57 PM
Dont set it up to stay soft all the time.
Quick Reply: rear motor mount
