rear motor mount
#21
You want to check the solenoid when it's energized vs de=energized. It's just a valve, open & closed. You can use (low pressure) compressed air, or some rubber hose & blow through it.
I don't remember if its open or closed when de-energized, but at least when you energize it, the valve should change.
#26
Sorry, is the mount busted or is there a question about its function?
Either way, at idle (~750 rpms) there should be vacuum to the mount - I think the line to the mount it the upper, the lower should be from the intake manufold
baer77
02-27-2009 03:47 PM
