Rear Strut
Nope haven't had the time to fix it. My Clutch MS went out changed that then the darn CV was popping out the ring was gone looks like it never had one replaced that.
Now i need to adjust my Clutch i bleed the system just fine once i get this fixed then i will fix the struts but i still need to know what part im i missing !!
in the vid it showes you what part your missing. Look closly when he takes the strut apart (even know it’s the front strut the rear goes together the same way) They guy when he installed it prob put the washer up top. Iv done it before and had to take it all apart and do it again. All it is a washer that stops the rubber from coming through the top of the strut housing. Look at the pic you posted...see how there is two washers?? One goes on top and the other below to stop the strut from coming through the housing.
