Removal of drivers side motor mount
Hi, what is the proper procedure to remove thge drivers side motor mount on a '96 Accord, 4 door LX automatic? I already have a diagram of the bolts / studs. For this particular mount do I need to support the engine with a jack under the oil pan? Anything else trickly? I need to remove the mount so that I can drill out the broken stud. Then I plan to reuse the mount with a new stud and nut.
RE: Removal of drivers side motor mount
I don't remember everything off hand, but yes you need to support the engine with a jack under the oil pan. I think there are three studs holding the mount to the frame and about 4 bolts holding the mount to the block. Once they're all out the mount should slide straight up.
Creepyjeeper
05-26-2012 04:48 PM
baer77
02-27-2009 03:47 PM
