Removing the "H" Emblem from Steering Wheel
Anyone have any knowledge on how to remove the "H" emblem from the steering wheel of a 2009 Accord 4DR Sedan without damaging the steering wheel or airbag? Not sure if I can just use the fishing line trick on the back of the emblem or if it's actually attached to the inside of the steering wheel. Any thoughts? Thx
I believe it is held in with tabs. You can pry it out if the cover was removed; but, if pried from the front may break it.
Just curious, why would you want to?
Here is a picture of the emblem from behind the cover. It looks like there are 13 tabs.
I don't recommend messing with the airbag though. You can buy the cover only through ebay... just enter 2009 Accord airbag cover.
joenintiesc
04-14-2013 07:29 AM
thunder_x
08-11-2007 10:31 PM
