Removing Rocker Arm Assembly
Old 02-25-2007 | 10:13 PM
MALSR's Avatar
Default Removing Rocker Arm Assembly
Just read the DIY for replacing lower rocker arm seals. I was planning on removing the the rocker arm asmbly while leaving the distributor on (I'll just remove the top bolt) and leaving the timing belt in place as well. Do I have to have someone hold down the distributor-side of the camshaft to keep it from popping up????
(F22a motor, auto tranny)
Old 02-25-2007 | 11:45 PM
hondadude's Avatar
Default RE: Removing Rocker Arm Assembly
No, don't worry,the camshaft will just lay there and play dead.
When you go back together use a torque wrench, and the propertightening sequence.
Old 02-26-2007 | 02:02 AM
ArcticHonda's Avatar
There's some good diagrams in the haynes manual for the tightening sequence.
RedLineZ_05
12-18-2014 11:08 PM
nezt674
06-21-2011 04:33 PM
KYWildcat
08-17-2009 06:24 PM
ArcticHonda
04-20-2007 10:53 PM
91boz
02-03-2007 12:48 AM
