Replacement EGR plugs?
Old 04-05-2012 | 09:38 AM
pancho88's Avatar
Default Replacement EGR plugs?
Hey guys, does anyone know where to get the replacement brass plugs for the EGR passages on the 2.2 non vtec sohc? Getting an EGR code so I have to drill them out and clean the passages so they will need to be replaced with new plugs. I called several dealerships and no one seems to know anything about them. Should I go to a hardware store? If anyone has dimensions that would help tremendously. Thanks for any help.
Old 04-05-2012 | 12:47 PM
Put your car info in your signature line. Plugs are only used on 90-93 Accords, and I think mostly in 90-91 models at that. If you're 94 or later there are no plugs, just a manifold to remove/clean.
If you have plugs, you can reuse them by potting the holes w/ J&B weld epoxy. That's what I did on my 90 Accord and it worked well.
Old 04-06-2012 | 05:12 PM
See if this PN works 17199-PT3-AHM
EDIT: Ok, I'll give up the source....google "T2T013"
ronjr8102
04-12-2011 09:53 PM
olgirlkeepsrunnin
01-31-2010 03:37 PM
RJLhonda
09-09-2008 02:05 AM
oma93
03-09-2008 03:48 AM
AccordEX
03-30-2007 10:49 PM
