Replacement radiators
I have a 1991 Accord wagon EX. The radiator has developed a split on the top reservoir seam that I temporarily repaired with JB Weld. I plan to replace the radiator, read the DIY description and am confident it is well within my skill set. My question is with the many brands available on the net, what are the best quality replacement radiators in list experience? or what should I avoid?
Thanks,
Bob
Thanks,
Bob
Lswpubrw,
I have found that the OEM radiator by Denso is a top-notch quality replacement radiator. It may not possess the cooling capacity of aggressive after market performance radiators from Mishimoto but it's entirely sufficient for street use. The OEM part number is 19010-PT1-908 and costs anywhere from $372 (dealership price) to $263 (OEM parts site price).
I would avoid buying after market radiators from autopartswarehouse.com or rockauto.com, as I've installed a few of these budget radiators for my friends in the past and they've had issues with leaks/fitment.
Just make sure that you conduct ample research before pulling the trigger on a replacement radiator and you'll be golden
Last edited by redbull-1; 07-20-2012 at 11:55 AM. Reason: removed live selling link
Two cents from a poorman, get quality rad hoses, I prefer Gates but that is me.
Then if this is an auto trans, be sure to get a couple of feet of trans cooler hose(must be rated for trans cooler use...fuel line WILL NOT WORK) and replace the rubber parts going to the bottom rad connectors....and plan on needing a bit if trans fluid or at least check it after.
Update on Denso availability
I ordered the Denso radiator but later they sent me an e-mail saying it's on back order probably available 9/9. I wonder if this is part of the Japanese fall out from the tsusami or if these cars are just that old?
Bob
Bob
