Replacement / Used engine
I have been trying to repair my engine after it overheated and blew a head gasket. It seems that there is more damage to the engine than I first noticed.
I have to make a decision..
The car has 330,000 miles. Suspension was replaced a year ago.
The interior of the car is a 9-10. The exterior is a solid 7-8. Outside of the engine the car drove beautifully.
My choices are
To sell my 2006 Accord as is, replace the motor with a used one and sell it or replace the engine and continue to drive it.
I do not have any experience with used engines and am a little skeptical. If I do buy one, what is the best way to ensure that I get a good motor? Will I have trouble smogging the new engine? I live in California ( strict smog regulations) can I still get an engine out of state that will work?
My questions.
Does anyone have any recommendations as to where to get a used engine? I know there are hundreds of places but looking for a recommendation.
Looking for an objective opinion as to whether I should keep the car or just bite the bullet and get a new car.
If I sell the car, should I replace the engine first so I can get top dollar for it? Or do you think best to sell as is?
I know there are a lot of questions here and I appreciate all of your help..
Mark
My choices are
My questions.
Mark
The best way to determine if the engine is good is to see if the supplier will give you a compression test and also a leak-down test. I linked a video below with someone covering buying a used engine. He is very thorough and has good suggestions. Not sure if everything he does is feasible.
You can try car-part.com to search local junkyards.
You want to match the K24A8 and the next 2 numbers from the engine block.
K24A8-XX.
I'd think that you would either sell as-is, or replace the engine and drive. I don't see why you would sell the car after spending the money on replacing the engine. You won't get the money out that you put into it.
K24A8-XX.
s4m222
12-22-2009 12:31 PM
kuvasz
04-20-2006 12:54 PM
