Replacing left low headlight bulb
Old 02-03-2012 | 12:47 PM
DScott 99 2.2 v6 ex at's Avatar
Default Replacing left low headlight bulb
Suggestions on how to remove or get around air intake to replace low beam bulb?
Old 02-03-2012 | 02:05 PM
For your 1999 V6, driver's side bulb, you need to remove the coolant reservoir to give you room to change the bulb. Remove the reservoir cap. Then I usually place my thumb inside the reservoir, while holding the outside the reservoir with my other fingers, and pull straight up (off the bracket).
kevinhhill
04-09-2014 04:13 PM
kouken
11-08-2007 08:39 AM
HondaAccordNewb
10-18-2007 06:51 AM
LotusDriven
07-20-2007 02:07 PM
sskkf
01-19-2007 04:23 PM
Quick Reply: Replacing left low headlight bulb
