rev problem
Old 11-01-2012 | 07:38 PM
pnutt7733's Avatar
Default rev problem
Hi Guys I am in need of some serious help. My 96 honda accord with a 4cyl 2.2 AT is doing some serious erratic revving. I have recently changed the idle air control valve and now the car "hunts" or idles erratically when I take my foot off the gas to slow down, especially when I am moving at a slow speed, between 30 mph and down. i am not sure how to proceed. Any suggestions out there? Oh, and I'm not that good of a mechanic, so dumb it down for me, ok?
Old 11-01-2012 | 07:59 PM
Roader's Avatar
Did you remove, clean and adjust the FITV when you did the IACV?
FITV Cleaning
Old 11-01-2012 | 08:34 PM
pnutt7733's Avatar
No I did not. I dont even know what a FITV is, but I also know that this problem started when my VSS (vehicle speed sensor) tripped AGAIN.
Old 11-01-2012 | 08:36 PM
pnutt7733's Avatar
Oh, and it guzzles gas like no tomorrow too
Old 11-02-2012 | 07:44 AM
I just looked at that thread & the picture links are broken.
Here's a picture of your throttle body. The FITV (fast-idle valve) is #14.
Clean it and/or remove the end plate & clean in there too. Tightening the plunger is also inside of that end-plate.
Also look for a thread by me about setting your "BASE idle". Do that stuff too.
Old 11-02-2012 | 10:11 PM
pnutt- if you replaced the FITV, then you had to remove some coolant hoses....be sure that you bleed the coolant system....air in the coolant can/will cause the same issues......just my 2 cents .
chavez69
10-28-2014 11:50 AM
JxATI
02-20-2014 01:34 AM
shynana
01-04-2012 12:57 PM
corey
07-02-2008 05:34 PM
Edinburger
03-10-2006 10:51 AM
