rough idle
rough idle
Driving a 98 accord lx. 4 cyl, manual trans. There is a rough idle unless i'm on the gas. When I go to accelerate the car jumps pretty bad. I have been told it is the idle air control valve however, I have read many posts on other sites that say that is generally not the problem. Any help with some trouble shooting?
Thanks
Thanks
RE: rough idle
Could very well be the IACV if it only rough idles when your off the gas. The IACV is supposed to allow enough air in when the throttle is completely closed. Not enough air = running rich = rough idle.
The only other thing I can think of is getting a new PCV valve ($3) and cleaning out the EGR ports.
RE: rough idle
ORIGINAL: finch13]Could very well be the IACV if it only rough idles when your off the gas. The IACV is supposed to allow enough air in when the throttle is completely closed. Not enough air = running rich = rough idle.
HatchJunki
03-09-2013 09:23 AM
NEPORTLANDMV
04-27-2012 01:21 AM
