rough idle
Old 05-21-2012 | 03:38 PM
bikr36's Avatar
Default rough idle
hi there new here and was needing some info if anyone cares to share some,please.so the issue im haveing is put a new timeing belt on checked double checked just about everything i can think of and now it has a rough idle.didnt have one before just wondering if i might have missed a tooth on timeing or anything else. anything will help right now thxs
Old 05-21-2012 | 08:34 PM
You mean excessive vibration? Check the balance-shaft belt for proper timing. Not the camshaft-timing belt per-se, but the balance-shaft belt is usually replaced along with it.
Surging idle? Revs up & down? Try adjusting the base idle.
https://www.hondaaccordforum.com/for...e-speed-38734/
Kpick
05-05-2015 09:51 PM
HatchJunki
03-09-2013 09:23 AM
NEPORTLANDMV
04-27-2012 01:21 AM
thejestersrace
05-26-2005 10:21 PM
mbliss
12-18-2004 02:33 PM
