'S' Light Blinked, Now It's Gone Solid...
Old 02-17-2010 | 06:19 AM
aerodeckbassie's Avatar
Default 'S' Light Blinked, Now It's Gone Solid...
Hi,
I've been reading some threads re Accords that get a blinking 'S' light.
We have a '92 (that's the body panel plate, tho VIN plate says 6/94) Accord Aerodeck here in Australia that's a U.S.-built model. A couple of months ago the 'S' light started to blink at times and was correspondingly sluggish, just like other people seem to experience. In the last week however the 'S' light has gone bright & solid and the sluggishness is constant. We have to drive it like a manual until we can get it to the shop!
I've had a quick look under the glove compartment to where people say the panel can be taken off to find the service connector etc, though I can't seem to identify it. Can someone give me a bit more guidance please? I know that once I uncover it I can short the connector and check the 'S' code blinks to find the code number.
Thanks in advance if you can help!
Old 02-17-2010 | 10:22 AM
g22cd5's Avatar
Supper Moderator
Something is wrong with the tranny...but we can't find out without a code.
Old 02-17-2010 | 02:09 PM
Old 02-17-2010 | 02:20 PM
g22cd5's Avatar
Supper Moderator
Should make that link a sticky...maybe we can reduce some of the auto tranny prob. questions.
Old 02-18-2010 | 05:33 AM
Thanks you guys. I'll take a look and post what I find. This sure seems common problem with the electronics...
Old 02-18-2010 | 09:57 PM
As a matter of fact there's not codes blinking at all as it turns out. What does THAT mean? Is the TCU fried?!
Old 02-20-2010 | 11:36 AM
hondadude's Avatar
A common symptom of a bad TCU is that the trans will shift okay one time AFTER the TCU is reset.
Warm up the engine...shut off the car .......get out and unhook the battery for 30 seconds...reconnect the battery...go for a test drive.
The next time you come to a stop and start off the 'S' light comes back again.
If that is what happens I would condemn the TCU.
techie768
12-09-2014 06:35 PM
slammed accord
05-25-2012 09:18 PM
palmer
09-19-2011 10:43 PM
Brandon Hollis
08-14-2009 05:07 PM
powerpeecee
06-06-2008 08:17 PM
