Screwy 93 Auto Transmission Problem
Old 05-14-2012 | 06:51 PM
glramos's Avatar
Originally Posted by muskokaman2
Hi guys...I appreciate your assistance....Only in fourth gear (top) does this happen. At highway speeds while cruising the car will momentarily jerk or lurch as it seems as if there's a instantaneous dead spot. It continues on it's way until it unexpectantly happens again.
Also I have noticed at times just when I'm about to accelerate (again while at highway speeds) it quickly lurches again. It's very frustating as the car upshifts and downshifts in every other gear perfectly.
The fluid level is fine and the right color and it was changed 15K ago. This started happening about 8K ago. I am the second owner bought in 2000.
Any assistance or direction would be much appreciated...Thanks
1993 2.2L SE Coupe Auto 175,000 K
sounds like the torque converter lock up clutch is going bad.
Old 05-16-2012 | 07:28 PM
muskokaman2's Avatar
Probably dumb one but here's a question....If I'm on my back looking up under the glove box how is it possible to see the D4 on the center console? Does it just cycle and continues to spit out the same code over and over. If so how do you know when it begins?...Dumb or what?? Please explain without rheeming me out to much.....
Thank you gentlemen. After your response I will begin the process and report back with my findings...,.I really appreciate your assistance.
Old 05-16-2012 | 07:34 PM
crispin's Avatar
Originally Posted by johntaps
First of all check it out your I am A SPAMMER . Also look for any damage of the I am A SPAMMER as well as clogged I am A SPAMMER. Any one of them when fails, there may be quick lurches while accelerating the car.
First of all ignore everything this spammer wrote ^^^^
Once you put the paperclip in you sit in the drivers seat and turn the key to the second position, at that point the D4 will start flashing, and yes it repeats the codes over and over
Old 05-20-2012 | 07:31 PM
Crispin,
Thank you for your patience, understanding and straight forward answer. I was ill the past two days and will perform the test tomorrow as explained. Thanks everyone who helped out thus far.
Old 05-20-2012 | 07:56 PM
crispin's Avatar
cool let us know the results
quint2
08-21-2017 08:28 PM
chadds
03-09-2012 04:05 AM
sskautos
04-27-2011 06:26 AM
kylefaust
03-25-2008 08:38 PM
dejavu247
12-04-2006 07:50 PM
Quick Reply: Screwy 93 Auto Transmission Problem
