seat help
RE: seat help
you might have a lifetime warranty on the seat height bushing/support kit, but i need your vin number to look it up.
did you check if the four bolts holding the seat to the car were tight?
does it feel only like a front to back looseness or side to side looseness?
RE: seat help
the main bolts holding the seat are tight, and the rocking is only front to back, all the seat adjustments work fine, i can move the seat where i want it to. i'll get you my vin number later when i dig my car out of the snow. and is the lifetime warranty covering multiple owners? beacue as far as i know im the second owner.
RE: seat help
you won't see it, it's a bushing. you'll need to remove a few nuts to find the bushings. they are form fitted, so only new replacement bushings will fit it. the rocking shouldn't be all that bad, just noticeable seat movement when braking or accelerating. if it's worse than that you might find something broken underneath.
JOE.G
11-04-2012 09:48 AM
MysticBlueEX
02-18-2011 07:55 AM
