Service Bulletin S03-062 - Seat Belt Slow to Retract
Old 07-28-2011 | 10:40 AM
19962door's Avatar
Talking Service Bulletin S03-062 - Seat Belt Slow to Retract
The driver's side seat belt doesn't always retract fully. At times, I need to pull the belt out fully, and then retract slowly while holding the belt.
I was able to locate Service Bulletin S03-062, dated September 16, 2003, which appears to have a fix involving cleaning the upper seat belt loop with isopropyl alcohol.
Has anybody tried this?
Also, how do you determine which bulletins apply to your model, in my case a 1996 Accord Coupe.
BTW, I tried to attach the bulletin, but the pdf file is too large.
Robert
Old 07-28-2011 | 11:47 AM
You can try cleaning, but I seiously doubt that will make much difference. The opening is quite a bit larger than the belt and there is just not that much friction. Yes, belt is somewhat dirty w/ age, but I don't think that is a problem.
I live w/ slow return rate and have to guide it back into place.
I would suspect the bearing needs lubing for the belt storage roller.
Old 07-28-2011 | 01:45 PM
19962door's Avatar
Did you ever notice most things to do with car repairs aren't easy?
I kind of figured the problem had more to do with the mechanism than the belt itself.
Is the belt storage roller the mechanism inside the back door panel?
Old 07-28-2011 | 06:10 PM
Yes, it's at base of car under the pillar trim.
dancamp
12-08-2012 08:05 PM
hondadude
DIY Answers.
12-23-2011 10:08 PM
ryder_kid
11-05-2011 12:09 PM
hondadude
DIY Answers.
03-02-2010 09:48 AM
jhualumnus
02-02-2006 07:46 PM
Quick Reply: Service Bulletin S03-062 - Seat Belt Slow to Retract
