seting timing 90 accord
Old 02-12-2009 | 01:36 PM
kounsryan
Default seting timing 90 accord
my 90 accord ex coupe two door is a little out of time i have a timing gun and i am not quite sure how to set it back in time
Old 02-12-2009 | 02:03 PM
finch13's Avatar
The distributor is the method of adjusting base timing, you should be able to loosen the 2-3 12mm bolts and rotate it. With the timing light on cylinder 1 (far right, drivers side) it should be in the middle of the 3 red lines on the crank pulley.
Old 02-12-2009 | 02:44 PM
I think back in '90 the timing marks were on the flywheel.
john_pyro
08-04-2019 06:06 PM
5.0stang
04-23-2013 07:37 PM
ss485
02-23-2011 09:18 PM
Jay 3rd
02-17-2008 11:54 PM
Tony1M
04-01-2007 06:42 PM
