setting timing
RE: srtting timing
I'm not sure what you mean when you say "from scratch". The timing belt needs to be installed properly with all of the marks on the pulleys lining up.
The spark timing is done by the ECU, but you can adjust the base timing. Loosen the distributor and turn it until the mark on the crank pulley is seen with a timing light. I don't know what the advance is for a 98 accord, but a haynes manual will have that information.
RE: srtting timing
barrow, its pretty tought to read your description of the problem. Please describe what happened in some detail.
Did the key break on the crankshaft or the bolt? Did the timing belt jump off its sprockets at all? I would certainly make sure that the timing belt is on properly, because your engine will get damaged if the belt is not on correctly.
Once you are sure that the timing belt didn't jump, then the crankshaft pulley can only be installed one way. The slot in that pulley goes over the key and the crankshaft bolt holds it all in place.
RE: setting timing
sorry about that when the pulley spun off and the key fell out. it left the cam belt free to turn at will. eg... not with the crank anymore. so I need to get the crank back in tdc. whats the best way. I need to get the cam in tdc again whats the best way. and c the ballancer is not set with the crank any more t belt popped off when pulley came off. so I need to know how to set the balance shaft cam and crank back in time. I cannpt merely line all the keyways up and install bc theres like a 2% chance I'll get the correct timing that way. not the chance I wanna take with a interference motor
RE: setting timing
i have the same exact problem.. my crank bolt snapped got it out and put the new one on but the key popped out and the timimg is all messed up.. so i need to kno the timimg marks to get it runnin smooth again.. for a 95 honda accord LX 2.2L
RE: setting timing
this is for the 2.2l I hope it helps
http://web.archive.org/web/200408131...meBalNote.html
RE: setting timing
I had a similar problem on my 97 Acura 2.5TL due to a shop error. I slowly turned the crankshaft and camshaft when necessary until both were aligned. You will feel the pistons when the contact the valves and must then turn camshaft to close valves. It took a while. In the end, it was for nothing as valves had been damaged by loss of the crankshaft pulley bolt. Head rebuild was necessary.
