shaking steering wheel when braking
My car Is a Honda Accord 1999 v4 Automatic. I'm sorry I don't know the engine size but I can put up pictures if that helps. Well I have a problem with my steering wheel shaking when I come to a stop. I want to know how I can fix it and if I should be worried? If you could help me out it would gladly appreciate it. Message me and If you need pictures of the ride.
Shaking "when you come to a stop"... ?
Brake rotors would cause shaking during braking.
If you really meant that it shakes after you stop, then there's other things to look at.
- engine mounts (especially the rear vacuum-operated one)
- idle RPM too low
- idle RPM too low
It's definitely a warped rotor. I usually just buy new rotors but getting them turned is generally cheaper but it's a PITA finding places to do that around here. In my experience If you're replace your rotors and pads spend the extra money and get quality pads. The rotors you can go a little cheaper on. I recommend Hawk HPS pads, run about $70-80 a set but well worth it. I have very good luck with the HPS pads and Centric brand rotors. Let me know how you make out.
Plumcrazebody
05-02-2010 05:19 PM
