side mirror turn sigal wiring for a 96 accord
RE: side mirror turn sigal wiring for a 96 accord
ok got then installed;
for all 1994-1997 honda accords the turn signal wires are easiest to splice by the main wire hub/2nd fuse box, which is at the drivers feet( by the left foot), right underneath the hood latch.
one turn signal wire is blue/green, and the other turn signal wire is blue/yellow.
just took off door panels and ran the wires through the rubber hose/grommet, zip-tied right turn signal wire to larger clusters of wires under the dash so it doesn't hang, but im gonna run it under the carpet when i redo the interior.
thanks to Haynes for creating auto repair/diagnostic manuals
helped out a lot
Take Kare
helped out a lot
Take Kare
iimzii85
11-01-2010 01:16 PM
