Sloppy shifting manual transmission gearshift lever. Reason for the issue?
What transmission fluid are you using. Now there are some transmission fluids that provide smoother shifts. And I think there are some transmission fluids that have the effect of keeping it as a hard shift. I think it depends on the car, so I'm curious what kind of car you use. Also, was there any recent changes to your car? Have you noticed this for a while?
Thanks. Honda OEM fluid, changed 6k miles ago.
I don't believe its a fluid issue. It shifts with a somewhat rubbery feeling. My son was driving it and when he tried shifting from 3rd to 4th it shifted into second instead. he did that twice while driving. I believe there are several bushings in the system and wonder if it could be the bushings at the end of the shift cable at the transmission? or at the shifter? maybe there's another reason for the issue? this is my first "modern" Honda. I'm used to the civics from the 90s which had shift rods, not shift cables.
Thanks!
Apparently Honda only sells the complete cable assemblies, but I found these (see link below) which are supposed to be a direct fit. they are also available on Amazon.
The material is:
"Made from Delrin. Delrin, also known as Polyoxymethylene (POM), is a high-performance acetal resin with several desirable physical and mechanical properties. This highly-crystalline engineered thermoplastic is widely regarded for its durability, stiffness, and exceptional dimensional stability."
I wonder if this material is harder than the OEM bushings and might have an adverse affect due to it's hardness?
https://www.torquesolution.com/Honda-Accord-Shifter-Bushing-p/ts-scb-504.htm
The material is:
Thanks!
The material is:
The material is:
Sorry, my previous post wasn't clear. My concern is more that the OEM bushings are most likely a softer rubber, thereby more forgiving to the transmission system than a harder "plastic'' would be. For example, I read that the metal bushings that were often used to replace the OEM rubber bushings in the old civics would cause damage to the transmission due to being too rigid. Don't know if that is true or not, but read it in several posts years ago.
Edit: Checked Rock Auto and they don't even sell the complete shift cables, let alone the bushings. Couldn't find any shift bushings on O'Reilly or Autozone website.
