slow leak
slow leak
Ive got a slow drip leakat the upper radiator hose clamp, engine side.
My ? is will I lose much coolant if I replace the hose and T stat?
And will I need sealant for the T stat gasket? Should I drain some coolant first?
RE: slow leak
You'll have to drain the coolant below the level of the hose first, theres a stopcock on the bottom of the radiator, its white. If the fluid appears to be okay and nice and green, you can put it back in the radiator, if not, replace it.
Shouldnt need to put anything on the gasket either... also, use a Honda t-stat, theyre much more reliable and accurate than the parts stores ones.
RE: slow leak
The T'stat is not in the engine side fitting on the upper radiator hose. It's on the lower radiator hose, engine side fitting. Usually air intake is removed to access.
florida
01-24-2015 02:42 PM
EBK142
07-20-2009 09:10 AM
xaznxeclipsex
09-28-2007 02:05 PM
