Some oil change advice if you could please...
Old 03-04-2008 | 03:43 PM
00AccordLX5spd's Avatar
Registered User
Default RE: Some oil change advice if you could please...
If I were you I'd switch to 10w30 Mike. Any time you get an engine with that kind of mileage a heavier oil will help prevent the leaks.
I think the dude was referring to swapping to 5w30 synthetic after having used 10w40 regular. That would be a huge difference in thickness.
Old 03-05-2008 | 09:21 PM
Mikebike125's Avatar
ORIGINAL: 00AccordLX5spd
That is what I was thinking. I have been running 5w-30 for a long time now and wasn't sure about going to 10W-30 or not. I know the 30 means it will be the same viscosity when hot be it the 5W-30 or 10w-30. When it cools down it will then be thicker 10 weight instead of 5 weight.
I'm going to see if my work on the gaskets slows things up enough that the leaking is not too much now. If it doesn't, I'll give the 10W- a shot next change.
Jae Min Chang
09-17-2013 05:23 PM
Pilot Mobbin
02-10-2013 09:07 AM
dr.honda
01-24-2012 03:26 PM
chris h
04-03-2011 11:01 AM
vtecHef
05-07-2008 10:34 PM
Quick Reply: Some oil change advice if you could please...
