Soooo close....overheating again
Old 02-23-2012 | 09:04 AM
First90AccordMan's Avatar
Default Soooo close....overheating again
Well it was doing fine and no more overheating...but the problems back again. I'm overheating at idle. My fans are working when I put a paper click to the coolant sensor on the t-stat. But now it's not turning on by the sensor. I just replaced it and bled the coolant system still not working. Could the sensor have gone bad already? Or am I missing something else. It's a brand new Oem sensor.
Old 02-23-2012 | 11:41 AM
When the engine gets hot touch both radiator hoses. Are they the same temperature? Or is one colder than the other. Be careful, because the hose are around the temp of boiling water.
Old 02-24-2012 | 06:16 AM
Thanks for the reply, I tried that and they do feel a little different in temp. So
I am guessing your referring to the thermostat. That's what I get for getting a aftermarket t-stat.
Now just a random question, do your know what kind of psi rating for a radiator cap I need?
Old 02-25-2012 | 09:28 AM
The cap is something like 16 psi.
n.dmello
09-10-2013 12:28 PM
g22cd5
08-24-2012 09:19 PM
ebarrera661
08-14-2010 12:28 PM
07-24-2006 04:55 AM
06-02-2006 03:24 AM
