speedo problems
RE: speedo problems
When speedometer fails, does the cruise control and tac stop working? If it does, then you probably have to replace the speed sensor (VSS). Its on the transmission and not too difficult or expensive to replace.
RE: speedo problems
I checked the S codes,I'm not sure if I'm reading them right.According to the service manual there should be 1 long blink followed by short blinks.I'm getting 1 fast,dim blink followed by short bright blinks.If I had to say what codes I'm getting,I would say 12,16,and17.Any advise?
RE: speedo problems
what about if speedo fails but cruise and tach still work? my speedo is stuck at 20 miles per hours but will work sometimes, normally after i hit a 100mph or after a while cruising. i bought the car used and it looks like they may have had aftermarket gauges installed. ie. 2 screws missing one on speedo and one on water temp gauge. oh car is 96 accord ex.
RE: speedo problems
assuming that you read them correctly
code 12.........EGR system
code 16.........fuel injector system
code 17....... speed sensor system ,,,,,,,,,,,,,,,,,, http://techauto.te.funpic.org/vss.php
chk the wiring going to the speeed sensor make sure they are ok,
daddy1902
06-15-2008 09:06 AM
PJ_STYLES_95AccordEx
08-22-2006 12:45 AM
