Speedo Quit Working
RE: Speedo Quit Working
Check the fuses.
If your cruise control still works when the speedometer is not working, then the speedometer is the problem. If the vehicle speed sensor stops working, the check engine light should come on and the cruise will not work.
The tach gets it signal from the ignition control module, so a working tach does not indicate the problem.
