Speedometer Error 1992 Accord LX
Old 09-24-2008 | 02:06 PM
bucktaz
Default Speedometer Error 1992 Accord LX
What could be the cause of speedometer error in a 1992 Accord? An indicated 65 mph is dead on 55 mph according to a known accurate GPS.
Old 09-24-2008 | 02:12 PM
falkore24's Avatar
Default RE: Speedometer Error 1992 Accord LX
wrong tires, wheels, sensor, aftermarket tweaking done wrong, pin on the speedo set wrong, etc.
Old 09-24-2008 | 07:23 PM
bucktaz
Sorry I wasn't more specific .. this particular vehicle has original wheels, Michelin Harmony® P185/70R14 tires. No work has been performed on speedo or instrument cluster. No suspension mods or tweaking.
Old 09-24-2008 | 07:31 PM
bucktaz
More info...speedo is accurate up to 35 MPH... error increases up to an indicated 65 mph (really 55 mph). Also an indicated 70 is actually 62, thereafter the percentage difference increase from indicated versus actual is very small. Speedo consistently shows ~ 20% error after an indicated 65 mph. Would a worn Vehicle Speed Sensor (VSS) present itself this way? No other symptoms of a failed or failing VSS exist.
Old 09-25-2008 | 11:13 AM
falkore24's Avatar
Sounds strange .... maybe VSS or a computer thing that's not reading the sensor voltage right.
BigShelby
12-18-2015 10:36 PM
mbaron
12-19-2011 01:21 PM
CasualObserver
12-14-2006 03:06 AM
duke16
03-09-2006 09:18 PM
duke16
03-05-2006 05:10 PM
