Speedometer not working, already replaced vss once, whats wrong?
Old 07-18-2011 | 09:42 PM
Tek310's Avatar
Originally Posted by 97 special edition
my speedo dont work and it is driving me nuts. i think i am going to try replacing the VSS any other ideas i that aint the answer? also the OD stopped working at 170,000 i was told when i bought it grrrrrrr. the title says mileage exempt. hit me back with any solutions and i will let you know how it turned out.
OD is nonfunctional with faulty vss
Old 07-23-2011 | 09:11 AM
97 special edition's Avatar
thx tek i will get the part and keep you posted on whats going on.
Old 09-26-2019 | 12:22 AM
zhou1225's Avatar
Hi, My Honda accord v6 2000 speedometer is always 5 miles faster. Is there any suggestion on solution? Thanks, Cheng
Old 09-26-2019 | 05:11 AM
shipo's Avatar
Assuming you're comparing your indicated speed to a GPS, the odds are you have the wrong size tires on your car are pretty high.
Old 09-26-2019 | 11:26 AM
The Toecutter's Avatar
Yup, my 99 is like that. It's off by 3mph (slow). But then I do have slightly larger tires on it, so I expect it to be off.
Old 09-27-2019 | 02:26 AM
zhou1225's Avatar
Hi, My tires were correct. Originally, me speedometer was not working. The mechanic changed the part behind and repaired it. But then it was 5 miles ahead. The mechanic said he did not know how to do it from there. Thanks
cukaracha
07-03-2015 12:55 PM
PeteGibson
06-27-2014 02:34 PM
mrmiller99
07-02-2011 07:07 PM
howheather
09-07-2010 07:18 PM
comptoncarl
02-08-2007 03:04 PM
Quick Reply: Speedometer not working, already replaced vss once, whats wrong?
