Squeaky Noise
Squeaky Noise
Hi,
The front suspensions (that's my best guess) seem to make a lot of squeaky noise (more or less like an old door) when I drive over a road hump. Any idea why?
Thanks for your help in advance.
RE: Squeaky Noise
does it ever happen any other time than a speed bump?
does it happen when you bounce the front end by hand? give it a good violent bouncing.
does it happen when you turn the wheels manually(key on, engine off) or power(engine running at idle)?
some creaky noise can be considered normal, unless it creeps into the above examples.
elijahpr
03-25-2013 06:19 PM
