Squeeky Brakes
Squeeky Brakes
I have a 98 Honda Accord Ex 2dr with a V6. I bought it about a month ago. It had squeeky brakes so I purchased four new rotors and two sets of pads and installed them myself. The rear pads that are against the piston have not been wearing evenly. After installing new parts the brakes still squeek. I also checked to see if the vacuum cover was rubbing the rotor. The sqeeky noise is only at slow speed 5-10 mph.
Any Thoughts
Thanks
Mark
Any Thoughts
Thanks
Mark
RE: Squeeky Brakes
Couple of things,, first off ,, what kind of brakes did you install ?? ( brand) .. some times a non-factory Honda pads will squeak.. also make sure that backing plate is not rubbing on rotor
also on the rear pads not wearing even,, did you position the caliper piston properly ?? made sure that the sliding pins were not sticking ??
