SRS code diagnosis and reset
1997 Honda Accord LX, 4 Cyl, 2,2L. SRS light is on suddenly (no accident, no collision).
Drove to Auto Zone, they refused to read the code for SRS (only for check engine light).
My questions (really appreciate your help, thanks in advance):
1. How do I check the code? can I just short the diagnostic plug (blue, two prong, under the glove compartment)?
2. To reset the SRS, where is the MES (memory erase signal) jumper? I read here people said it is under the steering wheel. But I found one (yellow, two prong) near the inside fuse box (driver side fender), plugged into a dummy yellow plastic container attached to the inside of driver side fender. is that it?
Thanks. I just read the code, which is 5-2. searched the web the only info I could come up with is:
Possible cause: Internal failure of the SRS unit
Corrective action: SRS unit replacement
anyone has more insight? does SRS unit include the two airbags? or just the control? Thanks.
1997 Accord LX 4Cyl 2.2L Auto
