srs light after remote start
Old 02-17-2012 | 12:12 PM
hookup11's Avatar
Default srs light after remote start
hi there,,, i successfully** installed a*remote*start*and keyless entry on my 96 honda accord and i might of bumped a wire accidently im not sure..i also reset the remote start module several times by turning the ignition on and off 5 times per reset durring programing. The srs light is now on..any idea if this is a major concern? where can i check the fust to start? or maybe rest? before taking it to honda dealership..thanks guys***
Old 02-18-2012 | 07:54 AM
There is a sticky at the top, Common DIY Threads, with a link to a manual you can download. It will give you the fuse numbers, also it will give you the reset and code readings.
Old 02-20-2012 | 12:36 AM
hookup11's Avatar
Default srs diy
Sorry for the stupid question but where is the sticky i went to diy section snd dont see nething on a 96 honda accord srs fuse locationn
Old 02-20-2012 | 09:26 AM
crispin's Avatar
Have you tried disconnecting the negitive terminal on the battery for a few mins yet?
Old 02-20-2012 | 10:19 PM
hookup11's Avatar
no i havent actually a co-worker suggested that to disconnect for 15 mins for reset..maybe ill try that out ..thanks
Old 02-21-2012 | 06:24 PM
Try this
https://www.hondaaccordforum.com/for...threads-40780/
Get the manual for the 94 and you should be good.
BoostinYou4Life
06-30-2014 03:31 PM
hookup11
02-16-2012 11:43 AM
razcob
07-10-2009 02:12 PM
alpha0r
02-11-2008 12:28 PM
jvaruzzo
11-04-2006 04:31 PM
