SRS reset, 2001 Accord LX
Hi, I'm looking for the write up on the procedure for resetting the srs light, but cant find it. I know its supposed to be in the DIY, but I guess Im not good at navigating these things. I know I need to short the yellow harness with two wires, but my accord has two yellow harnesses with two wires side by side. One is large and one is small. Thanks -Jake
On the 2001 Accords, the OPDS (Occupant Position Detection System) was a common cause for the SRS light coming on, and Honda had an extended warranty on it. The warranty extension appears to have expired.
The location of the MES (memory erase signal) connector, instructions, and info. regarding the OPDS are all included in this Honda TSB:
Honda TSB 06-009
Honda TSB 06-009
