Starter issue? Not sure..
Old 02-12-2006 | 02:20 PM
dude9571
Default Starter issue? Not sure..
My 94 Accord LX 5 speed recently has had problems starting. Sometimes it'll fire up on the first time, but most of the time, I have to play with the clutch and the ignition to get it started.
Sometimes it will try to start and I'll get one crank of the engine out of it, before I have to take out the key and try again. Other times, it just won't even try. Probably the starter, possibly the ignition switch?
Old 02-12-2006 | 08:32 PM
lightshow's Avatar
Default RE: Starter issue? Not sure..
it sounds like you are not pushing the clutch in all the way. if you want to start your car...push the clutch all the way to the floor. if you are doing this then you may be having a problem with the switch on your clutch. you can take the two wires leading to it and cut them and splice them together. you may have two switches though. one will disengage as soon as you start to press the clutch (this is for the cruise control and this is not the switch you want to mess with.) the other one will engage
gonnatell1
01-08-2009 04:19 PM
bardsleyb
04-16-2008 09:23 PM
abhimenon
03-24-2008 01:04 PM
bnjmnthrn
03-06-2008 06:05 PM
patcal
12-11-2006 03:09 PM
