Starting issue 95 accord
Old 08-31-2010 | 10:37 AM
Dts91's Avatar
Default Starting issue 95 accord
Hey everyone I'm new to the forum but I figured this might be the best place to get some help, I have a 95 accord with an H22a dropped into it. Recently I've been having starting issues, some times it starts right up and others I have to turn the key on and off very quickly for almost a minute, and every time I have to be on the gas pedal once it starts to crank just to get it to turn over. My question is can anyone give me some spots to look first for why my car won't crank over at the first turn of the key?
Dts91
Old 08-31-2010 | 08:06 PM
Is the starter turning the engine when you turn the key all the way forward to try to start the car? Or does nothing happen?
Old 09-01-2010 | 03:22 AM
Dts91's Avatar
It gives a quick click when I try to start it some times other times it starts to turn over with the first turn, other times it takes almost 50 turns of the key to get it to even start the starter to start to turn the car over. Basically sometimes I get Nothing othertimes it turns right over and I haven't got a clue why?
Old 09-01-2010 | 02:12 PM
There are two tests that you can do. When the car is not starting.
1. With the key in the start position by an assistant, make sure that black/white smaller wire on the starter solenoid has 12V.
2. Caveman test. When the car won't start, have someone hold the key in the start position. Hit the starter with the handle of a screwdriver with light/medium force near the two electrical connections. If the car starts, replace the starter solenoid and contacts.
Old 09-01-2010 | 04:15 PM
To me it sounds like the starter as well, the clicking is usually a good indication. Also the problem usually gets progressively worse.
The tests PAhonda gave you should tell you for sure.
94HondaAccord
03-08-2011 09:24 AM
stubs
08-06-2010 11:29 AM
leg_of_tape
07-16-2010 07:19 PM
jacks132
09-02-2009 11:28 AM
RDX
02-01-2008 06:15 PM
