Steering stiffens after engine heats up.
Old 07-19-2012 | 02:06 AM
moziz's Avatar
Default Steering stiffens after engine heats up.
I have a 1998 model of honda accord and after sometime of driving my power steering stiffens. I have changed the power steering fluid pump yet the problem persists. Kindly assist.
Old 07-19-2012 | 07:14 PM
Are you getting any "foaming" the ps res?
Also, are you using Honda/Acura approved ps fluid.
Old 07-20-2012 | 04:26 AM
moziz's Avatar
Thank you poorman212 for your response.
Yes i get foaming on the reservoir, especially when the engine is heated up.
About the fluid, I do not know the type my mechanic used.
Could the fluid type cause the foaming?
Old 07-20-2012 | 09:23 PM
The foaming would be where I would be concerned......usually that means "air" is getting into the system....btw air will compress,,,,just like air in the brake system,,,,doesn't work.
So I would start by checking for a bad o-ring on the connections, hoses or a loose return hose first.....can't remeber if the 6th gen's had the "filter" in the bottom of the PS res.....seen those get dirty and cause sim issues.
EDIT: the fluid is not "so much" a concern based upon the feedback.
mikebuddy
05-22-2015 01:12 PM
Sundevil81
11-08-2012 07:56 PM
sall
08-20-2007 10:22 PM
Quick Reply: Steering stiffens after engine heats up.
