steering wobble and power window
Old 01-08-2008 | 10:16 PM
manu_b's Avatar
Default steering wobble and power window
my accord`s steering woobles at slow speed but when i go at heigher speed its ok. i got my wheels balanced and i almost got rid of this problem but problem still exists, but after driving it for 60 km wieght of front wheel fell off. now i got them balanced again and problem is almost gone again. Also my both front power window regulator got fried, can there be a problem with wiring or something. Plz help me get rid of this problem.
________
Weed Vaporizers
Old 01-09-2008 | 01:02 AM
nafango2's Avatar
Default RE: steering wobble and power window
Power window motors do have a tendency to die out, but not at the same time.
i would start by checking the fuses, each power window has its own 20A fuse, however I would check all the fuses, both under the hood in the fusebox and in the fusebox by the pedals. check EVERY fuse. blowing one can do wierd things to your electrical system.
Old 01-09-2008 | 03:30 AM
JohnL's Avatar
A low speed steering wobble might be a damaged tyre. Feel around both front tyres and visually inspect looking for any lumps etc, sidewalls too.
Old 01-09-2008 | 09:21 AM
Ihad a bad tire once...
It would require re-balancing on a regular basis, but as much as I tried to inspect it, I couldn't see anything. No wobbling or squirming visible while driving alongside. Finally the separated belt began poking thru the surface.
Old 01-09-2008 | 08:51 PM
HondatechAV6's Avatar
if you've driven the tire on a flat it might has tore up the sidewall inside the tire. now there is a clump of rubber that is rolling around inside it. but you'd most likely get a problem at highway speeds from this. like stated, i'd suspect a bad tire(shift belt) with a low speed problem.
Old 01-10-2008 | 09:32 AM
manu_b's Avatar
this problem sometimes completely disappear thencome backagain. My car had broken engine mounts when i bought it so could it mean it hit curb.
________
NO2 VAPE REVIEW
deserthonda
03-17-2013 04:15 PM
AGronk
11-05-2012 08:12 PM
hot_diggity87
02-06-2012 10:01 AM
hondaredcar
04-15-2008 10:44 PM
scaht
09-25-2007 02:18 PM
