Still have surging and power issues
Old 08-29-2012 | 01:23 AM
AccorDats's Avatar
I solved the problem already, throttle has so much slack now it is tightened but not too much. Thanks for the inputs. More power HAF
Old 08-29-2012 | 02:35 AM
my1st.honda93's Avatar
Hey partner you mite want to do what i did before you go spend any hard earned cash!
What i did was take the entire air intake out(intake plenum)and clean the inside of it real good!what i used was a toothbrush and gas.
Its like cleaning the EGR ports only better!and clean the fuel injectors as well and throttle body.
Now you will need to buy 2 gaskets...the intake gasket and throttle body gasket,i believe i paid $27 for both.
do that then check to see how it runs?i had some what the same issue your having and i cleaned the intake,injectors and throttle body now she runs like a champ!
good luck!
Old 08-29-2012 | 09:45 AM
RobinsonRicer's Avatar
thats what my manifold swap was for
justmeedp@cox.net
10-05-2014 09:14 AM
justin's91
05-10-2013 06:05 PM
tiresthatgrip
08-10-2011 06:32 PM
GOT BOOST
11-02-2009 09:32 AM
Quick Reply: Still have surging and power issues
