Strange rubbing noise
I have a 2006 accord sedan 4cyl. with 73k miles. I hear a quick rubbing noise coming from the front of the car while rolling forward or backwards at very slow speeds. I hear nothing at high speeds. For example, when I first back my car out of the garage at less than 2 miles per hour I hear this quick rubbing noise that I think is coming from the passanger front of the car. Cannot reproduce this sound all the time. I have looked under the car observe nothing unusual. Other than this stange rubbing noise car drives and sounds perfect. Sometimes I hear this unusual rubbing noise while pulling forward after car has been parked. This noise is quick, but noticeable. All responses appreciated.
Local Honda dealership fixed a roaring wheel bearing on driver side for 300 dollars. But this rubbing noise has been there since i bought the car two weeks ago. Senior Honda tech test drove the car and hears nothing. Hard to re-produce. A service advisor thinks it is the ABS pump making noise, but I disagree. All responses appreciated.
Strange Pumping Noise
The strange pumping (rubbing noise) is coming from the ABS device under the hood on the passenger side. It pumps only once when I first start the car and move forward or backward in or out of gear. It makes this rubbing (pumping sound) EVERY time I start the car and move forward or backward. Sound only lasts for 1 second. No ABS light on dash. Car runs and brakes normal. Should I be concerned? Anbody else seen this situation before?
Buzzing noise resolved!
The buzzing noise is coming from the ABS running a self test according to a Honda shop foreman who test drove my car today. It runs this self test after every ignition startup driving slowly forward or backward for 1 second and does not run the test again until you start the car again. Thanks to all who responded.
FlyLow
05-08-2006 07:00 AM
