Strange temp gauge behavior
I was about 30 - 40 minutes into a one hour drive and I noticed the temperature gauge needle climb to about the middle mark on the temp gauge. It wasn't there long (maybe one minute), then returned to its usual position (about the 3/8 mark) for the rest of the ride. I was cruising about 65 mph indicated, so cooling air shouldn't have been a problem. At those speeds, I would think that the cooling fan wouldn't even be needed.
Anyway, on the trip home home, the same thing happened on the freeway after about 30 or 40 minutes. The needle climbed up to half for a brief time, then settled right back down.
The ambient air temperature when this occurred was below 40F both times.
The cooling fans work and the radiator is two years old (new at the time I installed the JDM motor). The thermostat is not a Honda thermostat. It's a Napa/Stant that the previous owner installed and I used it when I put in the JDM motor. The thermostat and the water pump are about 3 years old with about 22k miles on them. The coolant level is on the high mark.
Has anybody seen anything like this and been able to find the cause? I don't know if this is a "real" problem or just something that the gauge is doing independently of the actual engine temperature. I've never seen anything like this before.
I'll probably replace the thermostat with the Honda part ($32, ouch). Other than that, I'm at a loss.
Yes I have seen this before and there are two general causes, one the thermostat is getting stuck in the closed position or the head gasket is failing. 32 dollars should not seem like much of an ouch given the other potential. Rarely do head gaskets give advanced warning on Accords but sometimes they do... Civics will usually give some advance warning. If you were driving with the heat on did the temperature suddenly drop and then immediately come back?
The temperature selector was in the full heat position, but the fan was off. Air was not in recirculation mode, so fresh air was coming in through the HVAC, but not at a high rate. I didn't notice any sudden drop in temperature.
Thanks for the input, folks. I'll do the thermostat on Saturday and go from there.
pirulino23
11-10-2010 06:18 PM
elprezidente
05-04-2007 09:04 PM
