temp gauge pegged out
Old 01-27-2013 | 05:21 PM
BROCKINTN's Avatar
Angry temp gauge pegged out
I have a 1998 honda accord lx 2.3 and my gauge all of a sudden will peg out when you start the car up. The car is not over heating. I replaced the sender and the cluster and it still does it. I can disconnect the sender wire and the gauge will go down. I have the two clusters and know matter which one i put in it does it. Please help
Old 01-27-2013 | 08:18 PM
Strange - if it's OK with the wire disconnected, then it should be a bad sender.
I guess it's possible for your new sender to be bad right out of the box.
Try moving the disconnected wire around, pulling it this way & that. If that wire gets shorted to ground only in a certain position, that might help you located the problem.
pirulino23
11-10-2010 07:18 PM
wietgr
11-12-2007 06:41 PM
raf105
09-28-2007 03:55 PM
frombozeman
04-01-2007 02:23 AM
fperezal
09-29-2005 10:29 PM
