Throttle sticking?
RE: Throttle sticking?
if it was a carbed 87 it woud make a huge difference, plus if there was a recall for certain years then it makes a difference too.... lots of reasons really.... but I'm not here for that (for future referance if you just put it in your signature it makes life a lot easier)....
Can you feel the pedal stick? is it like the throttle cable is overly corroded or does the pedal return normally? if it doesn't return it could also be a problem with the return spring, does it only do it in certain gears? can you get the problem to re-occur while it's in neutral? If you can then go under the hood and mess with the throttle there while it's running and see if it sticks at all, if not it may just be that you have a frayed throttle cable that is catching
ORIGINAL: TedsF23accord
its a 98 why would that matter?
There is a service bulletin for your year with a sticky throttle.
Well i dont know how many 87 accords have f23's i dont know if ya missed it but it does say TedsF23accord and i fixed it so dont worry about it thanks for all the great help next time try not to be such a smart *** about it sorry i dont spend 20 hours a day on yourgay website where everyone thinks they're better than everyone else cause they spend 5 hours a day on it
