Ticking sound
Old 10-17-2007 | 10:39 PM
daniel216's Avatar
Default Ticking sound
hey, on my 1997 Honda Accord Ex V6 i hear this ticking. it starts when i turn on the engine (cold) and lasts for about 2 minutes and goes away. i dont know what it is. i changed the oil like 4-5 months ago. could that be a problem?
Old 10-18-2007 | 07:50 AM
daniel216's Avatar
Default RE: Ticking sound
anyone?
Old 10-18-2007 | 09:00 AM
falkore24's Avatar
Does your car take 5W20 or 30? I've seen a similar issue when 5W30 is used in a 5W20 car. Also, if you put your car info in a signature via your profile, more people will chime in to help you.
Old 10-18-2007 | 09:17 AM
Is it rhythmic with the engine speed? (lifters)
Or is it random timing? (exhaust getting hot & creaking)
Old 10-18-2007 | 09:51 AM
00AccordLX5spd's Avatar
Registered User
Can you tell where it is coming from? Pop the hood before you crank it, then crank it and look for the source of the sound. It's tough to diagnose a sound without either hearing it, or knowing where it is coming from.
From your description it could be anything from the ABS modulator, to a fan motor, to something internal.
Old 10-18-2007 | 04:56 PM
daniel216's Avatar
well it comes from the front of the engine near the grille. when i start the car i dont hear anything, but after about 1-2 minutes it starts off very quiet and gets louder. after about 2 mins the sound completely goes away. when the sound goes away it sounds like the ac compressor kicks in and the rpm's drop a little (this is normal). what kind of oil do you guys suggest for my 1997 Honda Accord EX-R V6?
Old 10-18-2007 | 05:05 PM
Registered User
Either 5w30 or 10w30 (depending on how hot or cold it is where you live). I use 10w30 here in MS cause it is hot most of the year round and rarely gets below 30. I don't believe Honda recommended 5w20 till the 98 & newer models.
Can you pop the hood and see if you can tell if it is coming from one of the fans? Is the clicking sound there when the a/c is off?
Old 10-18-2007 | 05:09 PM
daniel216's Avatar
yes the sound is there when the ac is off. i think its coming from the front valve cover or i could be wrong lol. i live in ottawa canada so its cold here in winters. i think the problem is that the oil in the engine has no viscosity left bacause i didnt have much time in changing it in the last 4-5 months. im going to try putting in some mobil 1 5W-30 and see if it gets better.
Old 10-18-2007 | 05:12 PM
Registered User
Ok so that probably rules out a faulty fan motor.I would try the oil change first. It sounds like it needs it anyway. Use 5w30.
Old 10-18-2007 | 05:17 PM
Registered User
Wait a minute....could it possibly be a clogged PCV valve. The PCV valve is supposed to make a clicking sound when pinched. It is in the valve cover. Have you replaced your PCV valve yet?(recommended every 30k miles I think - it's cheap)
