Timing Belt or Chain on my car?
Old 01-31-2012 | 12:14 AM
Accord Owner's Avatar
Default Timing Belt or Chain on my car?
Do I have a timing belt or chain? I think it needs to be changed at 105K. What if I change at 115K How far more can I go without changing it?
Old 01-31-2012 | 12:34 AM
4 cylinders have timing chain, 6 cylinders have timing belt. You have a timing chain. However, both cars also have a separate drive belt. Has your drive belt ever been changed?
Old 01-31-2012 | 12:46 AM
Is this a 4 or 6 cylinder?
Old 02-07-2012 | 12:06 AM
What is better to have?
I am not sure if the drive belt has been changed. How can I tell? I bought the car at 40K and now at 96K.
Four.
Old 02-07-2012 | 12:41 AM
Your 4-cylinder has a timing chain. The timing chain does not have a set interval to be changed, so the 4-cylinder costs less to maintain.
The V6 has a belt that needs to be changed. That service can be expensive. The interval to change the timing belt on the V6 is around 100K miles.
Old 02-07-2012 | 08:11 AM
On the 4-cyl K-series engine, I recall there's a way to look at the position of the timing-chain-tensioner. I don't remember the details, but as we get more miles on those engines we can think about that.
Old 02-07-2012 | 09:16 AM
Generally, the drive belt should be changed at 105,000 miles; or if there is damage to the belt; or if the gauge on the drive belt auto-tensioner shows the belt has stretched/loosen past a certain range (there is a gauge as part of the drive belt auto-tensioner that has an arrow and some lines representing belt tension range).
Some people call the drive belt a serpentine belt, etc. It is the one around the alternator pulley and other accessories.
Old 02-20-2012 | 05:07 PM
I have over 96K miles on my 4-cylinder. I want to wait as long as possible. How long should I wait? I don't have the manual but I think it said to change at 105K.
Old 02-20-2012 | 05:08 PM
I have over 96,000 now.
