timing belt due?
timing belt due?
What are the indications, other than mileage, that a timing belt needs replacement? I know that if it goes out on you then you're in big trouble, but I was just curious if there are any tell tale signs.
Thanks guys!
Sean
Thanks guys!
Sean
Thanks guys-- just for ease of typing I didn't give the full story in my other post. It's actually my brothers g/f car-- 01 civic with 110,000 miles on it. He says it kinds runs like crap and doesn't think it's ever had a tune up either. I as going to do thatuch for her anyways and I know the timing belt is due too so I was just going to knock both jobs at once. Also my 98 accord has 73,000 on it now. After reading your posts on here I'm thinking I'm good for another 40,000. Still original belts though. Should I just do my car now too?
Thanks again for all the great help. The projects start this weekend so I'll keep the updates coming!
Sean
Sean
The 2 timing belt jobs are sorta similar. Your Accord has a balance belt in addition to the Civic's timing belt. I think the 98 Accord calls for a timing belt every 105k miles or ?? years. Yours may be due simply by age.
The difficult part of the timing belt (both cars) will be removing the crankshaft pulley.
I've taken the car to a shop where they use a better impact wrench than what I own. Then put it on tight enough for me to drive 2 miles home.
Any extension on the impact wrench will reduce the torque. Better to use a short socket with no extension, as opposed to a deep socket.
Well, just an update.... This Crankshaft nut is a B!#%*H ! I just bought an air compressor and a 55ft-lb 1/2 in Impact wrench and my car is just laughing at me! Im going to have to go to the shop tomorrow and see if I can borrow a 3/4 impact. Oh well. I cant compalin too much, I havent broken anything..... yet.
Sean
Sean
